Gammasoft MylariaMaker
Post by Info-Mac » November 23rd, 1999, 11:00 am
Download: http://archive.info-mac.org/app/gs-mylariamaker.hqx
This program creates and reads descriptions of simple cartoon characters.
Included are the character files for my own cartoon, Mylar City. There is
also a MetaCard version of the program, if you want to debug and compile
it.
This file requires the Gammasoft Runtime Engine. If you don't have the
Gammasoft Runtime Engine, you can download it from this server or, if you
have MacOS Easy Open enabled, use the HyperCard Player instead.
When you decompress this folder, be sure to put it in the same folder as
the Main Menu file. Also put an alias of the MylariaMaker file in the `Data
folder. Make sure the alias doesn't have an " alias" suffix or a space
after it's name.
