Gammasoft Libsys
Gammasoft Libsys
Post by Info-Mac » November 23rd, 1999, 11:00 am
Download: http://archive.info-mac.org/app/gs-libsys.hqx
Here is a simple, small library automation system. It is for use on a
server on a Local Area Network. Since I just put it together one day, it
isn't very much.
This file requires the Gammasoft Runtime Engine. If you don't have the
Gammasoft Runtime Engine, you can download it from this server or, if you
have MacOS Easy Open enabled, use the HyperCard Player instead.
When you decompress this folder, be sure to put it in the same folder as
the Main Menu file. Also put aliases of the ADMIN and CLIENT files in the
`Data folder. Make sure the aliases don't have an " alias" suffix or a
space after their name.
