Download: http://archive.info-mac.org/app/gs-goodies.hqx
This is a collection of little programs that do little things. They haven't
made it into full-blown projects.
These files require the Gammasoft Runtime Engine. If you don't have the
Gammasoft Runtime Engine, you can download it from this server or, if you
have MacOS Easy Open enabled, use the HyperCard Player instead.
When you decompress these files, be sure to put the folder in the same
folder as the Main Menu file. Also put aliases of each file in the `Data
folder. Make sure the aliases don't have an " alias" suffix or a space
after their name.
Note: If you have the developement version of HyperCard or if you have
HyperCard of 2.5, you can bring up the message box (or the No Limits
Message Box if you have HC of 2.5) and type "apple2" (without the quotes)
in the Fonts program. In the bottom box you will see the words "Apple //e"
in the center, then after a few moments you will see an Applesoft prompt
with a blinking checkerboard cursor. Click the mouse button to bring the
program back to normal. This works best if you select an Apple II-ish font
and a size of 18.
