Gramotki 1.5.11J - Japanese Version
Download: http://archive.info-mac.org/app/gramotki-1511-jp.hqx
This is the Japanese version of the Gramotki package.
Gramotki is a much improved Stickies. Everything you wanted from a sticky
note and exciting features that will simplify notetaking on MacOS. Gramotki
may be run continuously. In addition to low memory requirements and full
drag-and-drop support, Gramotki is not encumbered by the 32K limit for
styled text. There are many other useful features that you will soon
discover. Installation is accomplished easily without an installer to deal
with.
New features in recent versions:
*Color menu (Text menu)
*Encrypted notes (Note menu)
*Export notes (File menu)
*Translucent drags
*Links between notes
*Improved "Find in all notes" feature
*Calendar Copy, that makes it easy to build calendar in a page-layout
application - Happy New Year!
and many more new features.
Changes in this version:
Contains fix for MacOS 9:
¥ visual effect in thousands and millions of colors
Other fixes:
¥ improved storage repair/optimization
¥ integrated changes from 1.5.9
