Download: http://archive.info-mac.org/comm/bbs/fc ... -trans.hqx
This patcher changes resources in your FirstClass 3.0 application so the
file transfer progress bar looks sort of like the one that Aaron gives you
in the Finder (i.e., like the one that will be in Mac OS 8). It may not
look right with older versions of FirstClass.
A backup of the original application will be placed in the Trash so that
you can retrieve it in case you change your mind.
Please note that any settings files which contain resources that also
modify the file transfer window will override the resources in the
FirstClass application. So, the effect of this patch will only show up when
you are using a settings file which has not already been modified.
