Download: http://archive.info-mac.org/gui/ks/sche ... -10pr2.hqx
Scheme Factory 1.0pr2
by Joe Stenger and Arlo Rose
Scheme Factory is the official scheme editor for the Kaleidoscope 2.0
scheme format. Whether you're a novice schemer or a seasoned professional,
Scheme Factory offers you the tools you need to make Kaleidoscope 2 schemes
quickly and easily.
You'll find that Scheme Factory offers a clean and easy to use interface
allowing you to create schemes as quickly as you can draw the elements for
your scheme. Scheme Factory is built with Apple's Human Interface
Guidelines in mind, so you can count on it to work the way you expect a
Macintosh application to work.
This version is a complete rewrite of Scheme Factory and is now able to run
on 68K Macs. It requires System 7 or higher and Apple's Appearance Manager
1.0.1 or higher. You can now paste cicn resources (icons) and ppat
resources (patterns) directly into your scheme using this version of Scheme
Factory; no more need to use a different program to do this. This version
also includes lots of other additions and interface tweaks.
