Powershare
Powershare
Download: http://archive.info-mac.org/comm/atlk/p ... are-10.hqx
PowerShare 1.0
PowerShare is a shareware program that allows anyone using System 7 File
Sharing to control the amount of CPU time allocated to File Sharing.
Without PowerShare, System 7 File Sharing defaults to 50% of the CPU time
allocated to File Sharing. PowerShare allows you to allocate anywhere from
10% to 100% of the CPU time for File Sharing. Once you use PowerShare to
change this setting, it will stay at the new setting ... even if the
computer is shut down and rebooted.
By allowing you to set a higher CPU allocation for File Sharing, PowerShare
can greatly improve the performance of File Sharing. If you are using File
Sharing, you need PowerShare to get the maximum performance. If you need a
fast server for a small network, with PowerShare, System 7 File Sharing can
compete with AppleShare's performance.
