Title Free V1.3
Title Free V1.3
Download: http://archive.info-mac.org/gui/icon/title-free-13.hqx
TitleFree is a MacOS application designed to create and use icons in the
Finder without any title (file name). Finder icons free of file names!
With it you can get rid of any icon name: under the trash, any hard disk
or cd-roms, or any other icon in the finder. And itÕs easy to use!
USAGE:
¥ First: With this new version, to show or hide any name under
any icon you just have to use the provided ÒTitle FreeÓ contextual menu.
¥ Show icon name: Show the names under the selected icons in the finder
(this option will appear disappear on purpose).
¥ Hide icon name: Hide the names under the selected icons in the finder
¥ Deactivate/Activate Title Free: To temporary activate or deactivate
any Title Free effect (any hidden name will then be visible).
¥ Reset: To reset ÒTitle FreeÓ, this can not be undone.
N.B.: Title Free does not change anything in the file (not even itÕs
name!).
¥ Second: Title Free will also hide any name ending by an under score
Ò_Ó, such as ÒTmp_Ó, or Òmy folder_Ó. This is a supported trick to
quickly create clean alias panels in the finder.
