SilverTwoTab3DRsrcs_v5.sit
Download: http://archive.info-mac.org/gui/icon/si ... srcs-5.hqx
Tired of the 'factory' installed Blue 3D folders that Apple stuck you
with? Don't particularly care for the Blue 3D folders available for
downloading? Don't care to run Kaleidoscope?
Then perhaps you'd like these folders instead.
The "Silver Two-Tab 3D Folders" is a set of ResEdit resources and a few
ready made folders to enhance the look of your Macintosh. The ResEdit
resources are designed to replace the 'factory' installed Blue folders
with Silver Two-Tab 3D style folders. The included 'ready made' folders
are designed to enhance the effect by enabling you to place custom
folders onto those folders that normally do not have a custom icon in
your System Folder.
Included in the archive is a "Folder Icon Maker" (version 1.5) resource
file so you can get started making your own Silver Two-Tab 3D custom
folders right away. Folder Icon Maker v1.5 itself is included in this
archive by permission of the author, Gregory M. Robbins. This is in the
form of an original StuffIt archive as downloaded from America Online.
This set works best with Mac OS 8 or later. For System Software (Mac OS)
versions earlier than OS 8 please look for "SilverTwoTabCoplandRsrcs_v3"
at your favorite info-mac archive.
Please see the included "Two-Tab 3D Read Me" file for more information
and instructions for installation.
Don't forget to look for the "SilverTwo-Tab3D" folder series as well.
Each archive/series contains 100 custom "ready made" folders for your
enjoyment.
Commercial usage of, or commercial distribution of, the contents of
this archive and/or the concept thereof, requires written permission from
the author.
The actual contents and intellectual concept of the "Silver Two-Tab 3D"
folders is Copyright of Steve Ebener, all rights reserved.
Contact information:
Steve Ebener:
Greyland - [email protected]
541/744-0568 - Fax: 541/744-0250
Macintosh Consulting & Troubleshooting
