Platinum Zip Icons, a set of 21 custom-designed Zip disk icons
Download: http://archive.info-mac.org/gui/icon/pl ... -icons.hqx
Platinum Zip Icons is a set of 21 custom-designed Zip disk icons
that you can copy and paste onto the standard flat-looking Zip disk
icons that show up on your desktop. These icons have the 3D
“Platinum-look” that is similar to MacOS 8’s built-in system icons.
You may use and distribute this file freely, as long as the entire
folder and contents are kept together, and this "Read Me" file is
included in the distribution. This package can be freely distributed in
electronic form on computer networks. It cannot, however, be
distributed by other means (such as printed form, on magnetic media, or
on CD-ROM) without permission from the author.
Visit AGRAPHA (http://www.agrapha.com/) for ideas on designing your
Web site and for free graphics to download.
