Download: http://archive.info-mac.org/app/floating-notes-11.hqx
What's the point of having notes if they're buried by other application
windows and you can't see them? Sure, Stickies is free, but FloatingNotes
"floats" on top of all other application windows so you can always see them.
FloatingNotes uses no system extension, and best of all, FloatingNotes is a
Carbon application so it works under OS X as well!
FloatingNotes automatically saves all open notes when you quit or when it
moves to the background. To delete a note, simply close the window.
FloatingNotes requires OS X, or OS 8 or 9 and CarbonLib 1.3 or later.
CarbonLib is free and can be obtained from your "Software Update" control
panel.
New for FloatingNotes 1.1:
-- Notes auto-save as soon as FloatingNotes moves to the background.
-- Edit windows and floating windows now display quicker (no more zoom
effects).
-- Click on a FloatingNotes floating window and FloatingNotes is brought to
the front so you can edit the note.
Maui Software
[email protected]
