Folder Icon Maker v1.1
Download: http://archive.info-mac.org/gui/icon/fo ... -112-x.hqx
Folder Icon Maker X
Version 1.1
Folder Icon Maker X is a Shareware icon utility program that can be
used to combine Mac OS X Finder icons. It was written in Objective-C
Cocoa and compiled on Mac OS X version 10.3.
To use the program, simply drop an icon for the background onto
the view in the upper left corner of the window and drop an icon for
the foreground onto the view within it. The program will composite
the two icons together, with the transparency intact, and allow you
to write the resulting composite to a PDF file, TIFF file, .icns file
or to the Finder's clipboard. From the clipboard, the icon may be
pasted into any Finder icon from the Finder's "Get Info" window.
If you like the program or use it frequently you may register
your copy at http://www.kagi.com or contact me directly via
email. The shareware fee on this utility is $5.00.
The current version of Folder Icon Maker X is 1.1 and may
always be downloaded at:
http://homepage.mac.com/niteowl69/.cv/n ... t-link.sit
Questions, comments, bugs?
Email: [email protected]
©2004 NiteOwl Software
