comm/atlk/appleshare-setup
Download: http://archive.info-mac.org/comm/atlk/a ... -setup.hqx
--========================_12021677==_
AppleShareSetup Control Panel
Copyright (c) 1991-1992, Apple Computer, Inc.
All Rights Reserved
by Jim Luther, Apple Developer Technical Support
The AppleShareSetup control panel is free software and can be
distributed freely by individuals. For commercial distribution or
bulletin board distribution please contact Apple Software Licensing.
AppleShareSetup is distributed "as is" and unsupported by Apple.
Please don't call Apple for technical support on this program.
********** System Requirements **********
This control panel only works with the AppleShare 3.0, AppleShare
7.1, and future AppleShare Chooser extensions under both System 6
and System 7. It does not work with the AppleShare 2.0 Chooser
extension under System 6 or the AppleShare 7.0 or 7.0.1 Chooser
extension under System 7 - the configuration features just aren't
there.
The AppleShare Chooser extension must be in the "Extensions"
folder under System 7, or in the "System Folder" under System 6.
********** What's it do? **********
The AppleShareSetup control panel lets you set or disable various
options supported by the AppleShare Chooser extension. With
AppleShareSetup, you can:
* Make specific AppleShare alerts "time-out" after a set amount of
time. For example, you can make the "The file server is closing down
in x minute(s)" alert automatically dismiss itself after 10 seconds.
* Completely disable all AppleShare alerts.
* Disable AppleShare "Greeting" messages.
* Disable some auto-mount features.
Full Balloon Help is provided under System 7. Turn on Balloon
Help (and read your AppleShare manuals) if you can't figure this
control panel out.
[email protected] | Eric Apgar alias Gar | I said it, NOT Apple.
Content-Type: application/mac-binhex40; name="ASSetup.sea"
Content-Disposition: attachment; filename="ASSetup.sea"
