DropIcon 2.0
DropIcon 2.0
Download: http://archive.info-mac.org/gui/icon/drop-icon-20.hqx
DropIcon is an easy to use "drag & drop" utility for adding custom
preview icons to image files, similar to those created by Adobe
Photoshop and other image editors. DropIcon is a must-get for anyone
who uses or works with graphic files. Adding custom icons to a
collection of files using DropIcon couldn't be easier. The icons
which DropIcon generates will save you enormous amounts of time,
energy and frustration -- never again will you have to open an entire
batch of images just to find the one you're looking for!
New In DropIcon 2.0:
- 32bit Icon Support
- Contextual Menu Plug-in
- QuickTime movie files support
- Batch Format Conversion
- and much more!
DropIcon requires:
- MacOS compatible, with 68020, 68030, 68040 or PowerPC chip
- System 7.1 or higher
- QuickTime 1.0 or higher
- 2 megabytes of available RAM
For more information, or to download DropIcon, visit:
http://www.abbotsoftware.com/software/d ... picon.html
