clip2icns 1.5.1
clip2icns 1.5.1
Download: http://archive.info-mac.org/gui/icon/clip-2-icns.hqx
clip2icns is a little utility is designed to help you create 32 bit
icons (which are available under MacOS 8.5 and above). Since Apple has
chosen (for the time being) not to release an editor, I've created
clip2icns to fill that gap. It takes a picture from the clipboard,
splits it up into the icon and mask, and either inserts it into a
current file or makes a new icon.
New in this version:
1.5.1 February 27 1999
- clip2icns should work again under pre 8.5 systems
- an error message is now displayed if a file that's in use is opened
- icons with custom IDs should be displayed properly
Mihai
