SuiteSweep 1.0.1
SuiteSweep 1.0.1
Download: http://archive.info-mac.org/gui/suite-sweep-101.hqx
SuiteSweep (PPC for MacOS) allows you to manage applications or processes in
logical groups. You can create groups of applications that can be launched
with a single click; switch between groups with a single click (hiding those
not in the new target group); show or hide a specific group; kill a group,
and a variety of other process managment functions. SuiteSweep automatically
tracks applications as they are launched, and adds them to its list of
launchable applications.
Groups are easily constructed by drag and drop from a dynamic list of
running applications to the group list, or by simply dragging an application
icon from the desktop into the group list. Most group actions can be
accomplished with only one or two mouse clicks.
In addition, most of the primary managment functions can also be accessed
via a contextual popup menu from the main window, a reduced size window, or
an iconized window. SuiteSweep is designed to take up as little screen
real-estate as possible.
The appearance of SuiteSweep can also be customized with any background
picture the user can create. Switching between multiple backgrounds can be
done from a popup menu in the main window.
History:
1.0.1 / minor update to fix some defects
1.0 / first public release (11.dec.2000)
license: shareware $15.00
