ShiftSelection 2.0.2E
Download: http://archive.info-mac.org/gui/shift-selection-202.hqx
Version: 2.0.2
Requirement: System7.6/Mac OS 8 or later
Description:
ShiftSelection lets you to select text by "Shift"+"Arrow"
in the field where you can not select text ordinarily.
For example, finder's icon name, information window in Finder,
field on find window or on dialog boxes.
In almost one line fields, you can use "Shift"+"Arrow" to select text.
And, using "Modifier"key+"Arrow", you can move carret
with a rule. We call this function "CarretMoving".
For example, by word, by sentence, to start/end of line...
Moreover, you can create setting for each application about following.
*ShiftSelection On/Off
*Shift key Selection On/Off
*CarretMoving On/Off
*CarretMoving behavior for key combinations
Version Notes:
In this version, we fixed following.
*Fixed bug that you cannot add applications in external volumes.
*Modified drawing icon of buttons and list.
osato
mailto:[email protected]
http://www06.u-page.so-net.ne.jp/ga2/so ... index.html
