QuitApp INIT 1.0.1 - Drag the INIT QuitApp in your System
Folder:Extensions. You can Quit any running application from any
application. You can switch to any running application from any
application. Click mouse with holding keys Control and Command , you
abtain a menu where you clicked select Quit or Switch.
