QuickTrash 2.0 for MacOS X
Post by Info-Mac » May 19th, 2003, 9:00 am
Download: http://archive.info-mac.org/gui/quick-trash-20.hqx
What is QuickTrash?
QuickTrash is a little application that can stay in the Toolbar of
Finder window. In this way, it appears in every Finder window opened
and it can be reached at near distance than the Trash in the Doc.
In order to move selected files or folders to the Trash, first select
the files or folders as normally you would. Then one click on the
QuickTrash icon will do the job.
Why use QuickTrash?
Have you ever been tired of dragging files or folders to the Trash in
order to delete them? Did you drop them many times in the wrong folder
or in the dock while you are trying to throw them away? Sure, there is
a contextual Finder menu with control key that you can use to "Move to
Trash". This still requires two hands. QuickTrash lets you do this
type of work with one click!
Contact
QuickTrash is a Freeware and thanks to the wonderful ProjectBuilder
from Apple Computer, Inc. However, the idea of such application is
genuine and the author had it for a long time. If you like the
application, please send a postcard. All comments and suggestions are
welcomed. If you are a publisher and would like to distribute the
software, please contact the author and get the permission.
Via mail: Kevin S. Lim
4517 Ojai Loop Union City, CA 94587
Via email: [email protected]
