Program Switcher v5.6.0
Post by Info-Mac » April 30th, 2001, 9:00 am
Download: http://archive.info-mac.org/gui/program-switcher-56.hqx
Program Switcher is a convenient, timesaving control panel that allows you
to switch between the applications running on your System 7.1 through 9.x
Macintosh via a simple two-key keystroke. It was inspired by the same
function found in "Windows," but has been improved and transformed into a
unique and fully configurable control panel that makes switching
applications on the Macintosh as simple as pressing a couple of keys.
Key features include:
- The ability to switch, launch, quit, or hide any application with a
simple keystroke
- The ability to switch, hide, or close windows with a simple keystroke
- Full support for the latest MacOS technologies, such as Appearance,
Navigation Services, and Multiple Users.
- Elegant, unobtrusive interface that makes the seemingly simple task of
switching applications truly simple and easy to do.
- A powerful suite of user configurable hot keys, including such actions
as "Open File" and "Quit All Applications".
Program Switcher can be downloaded from it's web page at:
http://www.programswitcher.com/
New in version 5.6.0 is the ability to define hot keys and add applications
to the launch/exclude lists by drag and drop from the Finder, plus a number
of minor bug fixes.
