Popup Navigator 1.2b1J - Japanese Version
Download: http://archive.info-mac.org/gui/popup-n ... 2b1-jp.hqx
This is the Japanese version of the Popup Navigator package. The
Japanese version of this freeware utility is provided as a service of
Bridge 1 Software
You know the popup menu you get when you command-click a Finder (tm)
window$B%f(Js title bar? This control panel adds similar
functionality to most applications.
This version requires System 7.5 and works in a very simple manner: it
looks for a unique open file of the same name as the window, and
displays the popup if found. The filename must be the same as the
window$B%f(Js title. If there is no matching file no popup will
appear and the window will drag as normal. If there is more than one
matching file, a small disabled popup menu will appear telling you this.
If the navigation popup menu appears, you can drag through it; if you
select an item, then Popup Navigator tells the Finder to display that
item. Just like folder windows in the Finder!
Christopher Li
Bridge 1 Software
English/Japanese Japanese/English
Software Localization and Management
mailto:[email protected]
