PokeCursor 1.0
PokeCursor 1.0
Post by Info-Mac » August 12th, 1999, 9:00 am
Download: http://archive.info-mac.org/gui/poke-cursor-10.hqx
PokeCursor 1.0
By: Chris Lambert
(c) 1999 Total Software
PokeCursor is a system extention that changes the normal, boring, Mac
cursor to a PokeBall! To use it, just plop it into the Extentions folder
which is located inside the System Folder, then Restart. When your
computer has restarted, you should see that your cursor has changed into a
PokeBall. If it didn't, please email me at: [email protected]
Also, please note that PokeCursor is shareware, and is not free. If you
like it and continue to use it, please send whatever ammount of money you
think is appropriate to:
Total Software
508 Davisville Ave.
Toronto, ON
M4S 1J3
Canada
Thank you!
(PokeCursor is in no way associated with Nintendo, GAMEFREAK or Creatures
Inc.)
