Out! 1.0 - Close different
Post by Info-Mac » February 28th, 2002, 11:00 am
Download: http://archive.info-mac.org/gui/out-10.hqx
Out! 1.0 - Shareware $10
Close different.
Out! Home Page: http://kebawe.com/out/
Online Registration: http://order.kagi.com/?OL
Author email: [email protected]
Out! is an extension that closes your windows when you drag them outside the
screen. It works on MacOS 9.
You can press the Option key while dragging to temporarily deactivate it.
Out! plays a sound randomly chosen in the 'Out! Sounds Folder' inside your
Preferences folder when it closes a window.
You can use one of the desktop pictures specially designed for Out! They are
very nice and provide a line near the border of the screen: if you drag
outside the line, the window is closed.
Out! can be included in CD-ROMs.
