OtherMenu 2.0 (a hierarchical menu extension)
Download: http://archive.info-mac.org/gui/other-menu-20.hqx
OtherMenu creates a system-wide hierarchical menu somewhat like the Apple
menu.
Besides opening applications and documents, it runs 28 little utilities
called externals. In a directory dialog (Open/Save dialog), you can use the
menu to select a file or folder. Compatible with System 7 through 8.1.
Some PowerPC code. Shareware, $10.
OtherMenu 2.0 is at long last able to display icons in its menus. This
feature requires the Appearance Extension from Mac OS 8. There are many
other improvements and bug fixes.
-- James W. Walker
