Download: http://archive.info-mac.org/gui/nova-301-68k.hqx
NOVA, first and foremost, is a very stable Screen Saver environment. It
was designed to take up a minimum amount of RAM and work without the use
of any nasty extensions that generally cause instability in the MacOS.
NOVA provides three main services to the user: (1) eliminates the
potential for phosphor screen burn-in, (2) provides security for your
system, and (3) provides entertainment for yourself and those who work
around you.
Summary of what's new in 3.0.1:
1. Password security fix.
2. Password dialog shows cursor now.
3. Colorware Saverlet has been updated.
5. Swarms (PPC only) was updated.
6. Updated Clock saverlet to have a cooler "Digital" clock.
7. All Saverlets, the Launcher and Settings were recompiled with
Codewarrior Pro 4.
Requirements:
System 7 or higher, 68K Macintosh (for PowerPC, see the PPC version)
For further information:
web: http://www.chaoticsoftware.com
e-mail: [email protected]
