Download: http://archive.info-mac.org/gui/haxial- ... r-0902.hqx
Haxial Launcher is a program designed to make it faster and easier for
you to launch/open other programs, documents, folders, or URLs. Launcher
allows you to create buttons with menus that contain the items you want
quick access to for launching. Alternatively you can setup abbreviations
for items, for example, type "ml" into the text box, hit return, and your
mail program will open (if that is how you configured it). You can also
assign system-wide Hot Keys to open programs etc. For example, wherever
you are, merely hit the F9 key and your web browser will open (if that is
Haxial Launcher is available for:
MacOS 9 or better (with CarbonLib 1.3.1+, 1.5 preferred).
MacOS X (10).
Windows 95 or better.
The Product Page is here:
http://www.haxial.com/products/launcher/
And the company website is:
________________________________________________________
http://www.haxial.com [email protected]
