Finder View Settings 1.2 for MacOS 8 - global folder views
Post by Info-Mac » April 21st, 1998, 9:00 am
Download: http://archive.info-mac.org/gui/finder- ... ngs-12.hqx
Program: Finder View Settings 1.2 FAT
Author: Alessandro Levi Montalcini
Price: $10 (shareware)
Register: http://order.kagi.com/?67
Download: http://www.montalcini.com
Finder View Settings makes it much easier to manage the new
MacOS 8 folder-specific view settings. It can globally override
all of your folder-specific view settings, making MacOS 8 behave
more like System 7, or easily change the requested view settings
for single folders or entire disks.
To globally override the view settings, Finder View Settings
must be stored in the Control Panels folder so it can patch the
System at startup. You can then enable or disable the Finder
overriding option with the appropriate check box in the main
window.
To permanently change the view settings for a given set of
folders, you can drop them on the Control Panel's icon or into
the main window. Finder View Settings doesn't have to be in the
Control Panels folder for this to work.
New in version 1.2:
- Fixed an incompatibility with Virtual Desktop and other
third-party utilities.
