DragAnyWindow 4.5 fat - Live window dragging
Download: http://archive.info-mac.org/gui/drag-any-window-45.hqx
Program: DragAnyWindow 4.5 FAT
Author: Alessandro Levi Montalcini
Price: $10 (shareware)
Register: http://order.kagi.com/?67
Download: http://www.montalcini.com
DragAnyWindow is a way cool control panel that enhances the
look and behavior of window dragging. When you drag a window's
title bar and Solid Dragging is active, the whole window image
is moved instead of a dull-looking window outline. If the Update
Windows option is also active, all windows are updated on the
fly without waiting for you to release the mouse. Not as fast as
the BeOS, but definitely better than the standard Mac OS
behavior!
DragAnyWindow also allows you to easily move any kind of
window, including dialogs, alerts, standard "Open" and "Save"
dialogs, game windows and other non-movable windows. It lets you
bring back to the desktop any window that has gone out of sight,
or center the front window on the main screen with a single
keystroke. These options are very useful for old applications
designed for the 9" screen (which often use fixed windows) and
for moving modal dialogs and windows behind them.
New in version 4.5:
- Updated for Mac OS 8.5.
