Download: http://archive.info-mac.org/gui/dockdisks-10b41.hqx
DockDisks is a hack that causes disks to auto-mount in the Dock. This
can be handy if you want to put your dock on the right side of the
screen but want to avoid the conflict for space with the disk icons on
the desktop. It can also help avoid the problem of desktop icons
becoming covered up by open windows.
DockDisks is a hack, and as such it is obviously not perfect. The main
caveat is that the Dock is quit and relaunched when the list of disks is
refreshed, because the Dock has no API for adding/removing items, and
thus has to be relaunched to refresh its settings. However, DockDisks
does do its job, which is to put your disks in the dock.
Current features:
- Preference pane interface
- Can be set to automatically launch at login
- Automatically mounts disks when they are inserted
- Automatically unmounts disks when they are ejected
- Automatically ejects removable disks and servers when they are
dragged off of the dock
- Allows the user to choose whether to display fixed disks, removable
disks, servers, or any combination thereof in the dock.
- Allows the user to choose the area of the dock in which the disks
will appear
- German localization by Sebastian Krau=DF
- French localization by Ronald Leroux
