Default Folder F-3.1.2 - French Open/Save dialog enhancement
Download: http://archive.info-mac.org/gui/default ... 312-fr.hqx
This is the latest version of Default Folder, localized for
French-speaking users by Philippe Bonnaure. Default Folder F-3.1.2
should replace any previous French-language versions of Default
Folder in the archives.
Default Folder is a Mac OS 9.1 and OS X Classic savvy control panel
that enhances Open and Save dialog boxes to make it easier for you to
manage files on your Macintosh. It provides many of the essential
features of commercial utilities like Action Files, SuperBoomerang,
and Directory Assistance, but without the infrequently used extras
that take their toll in compatibility, memory, and CPU usage.
In addition, Default Folder fully supports the Navigation Services
Open and Save dialogs available in Mac OS 8.5 and higher, allowing
you to access your recently used and favorite folders everywhere.
What's New
Default Folder F-3.1.2 now allows users to change the Finder labels
on files and folders from within Open and Save dialogs with Default
Folder's Get Info command. The new release also includes
compatibility fixes for users of Photoshop 6.0.1, AdobePS, and
Extensions Strip.
Full details are available at:
More About Default Folder
Default Folder's time-saving Open and Save dialog enhancements allow you to:
- Set up a default folder for any or all applications.
- Switch among recently used folders from a pop-up menu.
- Easily navigate to your favorite folders.
- Share common sets of recent and favorite folders between all Open and
Save dialogs, including Navigation Services dialogs.
- Click on a Finder window to list its contents in an Open or Save dialog.
- See available disk space and switch between disks from a pop-up menu.
- Open the folder shown in an Open or Save dialog in the Finder.
- Create folders, get information (including changing name, type, and
creator), and move items to the Trash from within file dialogs.
- "Rebound" back to the last file you used.
- Make "Replace" the default option instead of "Cancel" when saving a
file with the same name as an existing file.
Default Folder will operate on any Macintosh running System 7 or
higher, including Mac OS 9.1 and the Classic environment of OS X, and
is $25 shareware. A complete description, details, and screen
snapshots can be found at:
