CSM Pack 1.2
CSM Pack 1.2
Download: http://archive.info-mac.org/gui/csm-pack-12.hqx
**** What is CSM Pack? ****
CSM Pack v1.2 is a $10 set of 6 modules for Apple's Macintosh Control
Strip.
These modules make day to day tasks easier. The modules include:
* Peek-a-Boo Strip which controls how much CPU time the
front application gets.
* IP View displays the IP address currently assigned to
your machine.
* Open Tray helps you easily open the CD tray on
PowerBooks and hard to reach desktop Macs.
* Window Genie makes the desktop easily accessible by
hiding or showing the application windows.
* Open File Count displays the current count of open
files on your machine. This can be helpful to gauge
just how loaded down your computer is. It's also useful
for QA type work.
* Activate Strip is used to quickly activate your After
Dark compatible screen saver.
**** What is new in CSM Pack 1.2 ****
CSM Pack 1.2 introduces a Peek-a-Boo control strip which supports the
Peek-a-Boo application by enabling the easy manipulation of how much CPU
time the front-most application gets. Peek-a-Boo can be found at:
CSM Pack 1.2 has an added feature for the Activate module. In addition to
activating the screen saver from the control strip you can now turn the
screen saver on and off. This is especially useful for extended
operations such as burning CDs when you do not want the screen saver to
activate.
A bug was fixed which prevented the registration key from working under
OS 9.1.
**** Download and contact information ****
A full demo version, screen shots, and ordering information is available
at the CSM Pack web site:
http://www.clarkwoodsoftware.com/csmpack
Inquiries, comments, and questions may be directed to:
CSM Pack 1.2 copyright (c) 2000-2001 by Clarkwood Software, LLC.
