Clip Changer CSM 1.2
Download: http://archive.info-mac.org/gui/clip-changer-12.hqx
Clip Changer is a Control Strip Module that process various filtering to
the text data in the clipboard.
* Insert/remove quote - This will insert/remove quote character '>' to/from
the top of the each text line.
* Remove line breaks - This will remove line breaks from the end of wrapped
text line. It's not the simple removal of line break characters, but more
intelligent removal so that result text looks more natual.
* Insert/remove TAB - This will insert/remove TAB code to/from the top of
each text line.
* Strip off HTML Tags - This will remove the Tags from HTML document
intelligently by considering the characterictics of each tag so that you
can see the text as you see them with the browser.
* Decode form data - This will decode the form data from browser that is
sent when you use 'mailto' for the action of the form.
* Decode Base64 - This will decode Base64 data that remains encoded for
some reasons.
* Decode Quoted-Printable - This will decode Quoted-Printable data that
remains encoded for some reasons.
* Save as a clipping file - This will save the current content of the
clipboard into a clipping file. This works not only for text data but also
for sound and picture data. A new clipping file will be created in the
desktop.
** What's New with 1.2 **
1.2 has fixed some bugs in the 'Strip off HTML tags' function, and has
improved this function so that the result get closer to what you see in
the browser's window.
by Hide Itoh
