AppearanceHopper 1.5 - utility for Mac OS 8.5 or greater
Download: http://archive.info-mac.org/gui/appeara ... per-15.hqx
AppearanceHopper fills customization holes in the standard Mac OS
8.5, by giving you access to features that are not editable from the
Appearance control panel. AppearanceHopper allows you to: set the
font, size, and style of the System Fonts; access the "hidden" scroll
bar options; set the style of alias names, and turn off the arrow
badge on aliases; and modify the Application Switcher palette, all in
one user-friendly control panel.
AppearanceHopper is $9 shareware available in English and French;
after ten trials, you must register the software in order to continue
using it. Mac OS 8.5 and AppleScript are required.
Weedhopper Press
http://www.whpress.com/
