AMICO 2.1.1D - German Version
Download: http://archive.info-mac.org/gui/amico-211-de.hqx
AMICO 2.1.1 (An apple menu utility) - German version
AMICO is a utility that helps you change the order of the items that
appear in the apple menu. It also lets you insert divider lines between
these items.
AMICO can be included in CD-ROMs or posted to any software archives or
BBS's.
For more information read the "Read Me" file.
You can contact me via email at: [email protected]
The current AMICO home page is: http://users.hol.gr/~macweb/amico
A NOTE FOR MAC OS 8 USERS
AMICO is Mac OS 8 compatible. However, to ensure that AMICO will function
properly under Mac OS 8, you need to check the "Always snap to grid"
checkbox in the "View Options..." dialog box of the Apple Menu Items
folder and possibly do a "Clean Up" for that folder as well.
