AliasMenu 2.1.1J - Japanese Version
Download: http://archive.info-mac.org/gui/alias-menu-211-jp.hqx
This is the Japanese version of the AliasMenu package.
AliasMenu is a control panel that adds customized menus to the menu bar.
These menus work like the Apple menu: Each menu has a corresponding
folder and the menu automatically reflects the folder's content.
The menu name can be replaced by a custom icon, to get a nice layout
or to save room in the menu bar and add more menus.
AliasMenu 2 features:
* Menus are present in all opened applications.
* The number of menus is unlimited.
* Menus can be added after the application's menus, or inserted before.
* Keyboard shortcuts are always active and can use any modifier key.
* Ordering menus and items is easy. Separators can be inserted and
removed on the fly.
* Items of any kind can be put into a menu: folders, applications,
documents, servers, scripts, and URLs. Use AliasMenu to create several
cross-application bookmarks menus, always available.
* Multiple launching: launch several items with a single keystroke or
menu command.
* Automatic text typing: put a text clipping in a menu to 'type'
its text in any application.
* AliasMenu can trigger FKeys from separate files, allowing the use
of an unlimited number of FKeys with user-defined key shortcuts.
System requirements: System 7.0 or better, MacOS 8.1 or more is
preferred.
Hardware: Any Power Macintosh or any Macintosh with color capabilities.
