11th September Interarchy interface submitted
Download: http://archive.info-mac.org/gui/11th-se ... erface.hqx
How to install this interface
* Launch Interarchy (version 3.8 or higher)
* Select "Preferences Folder" from the "Settings" menu
* Drag the file "11th September" into the "Home Items" folder
* Switch back to Interarchy
* Select "11th September" from the "Home" menu items and use it
* If you wanna make "11th September" the default interface return to
Finder and place its alias from the "Home Items" folder to the "Startup
Items" folder removing any other item inside. Then restart Interarchy.
GOD HELP US!
Franco Ventimiglia
Contact Info:
Please send comments to:
11th September Interarchy Interface ©2001 by Franco Ventimiglia
©2001 by Apple Computer
