WordPerfect 3.5e patch
Download: http://archive.info-mac.org/text/wp/wor ... -patch.hqx
This patch for WordPerfect 3.5e does three things:
1. makes the application incredibly stable.
2. adds several commands to the enhanced outlining.
3. fixes every bug that WP and a fine group of beta testers could find in
nearly three months of testing.
It patches WP 3.5e, but not earlier versions (the CD with 3.5e, several
hundred truetype fonts, a ton of clip art, etc., is available for about $25
to every registered owner of WP 3.5 and later. That's available at
800-772-6735).
To install the patch, move or rename your Library first. Run the patch, and
then copy your macros, keyboards, button bars etc. from the old Library to
the new. Do not copy any outlining macros, as updated outlining commands
have been incorporated into the program itself.
The patch is free.
John Rethorst
