Download: http://archive.info-mac.org/text/qark/t ... tte-15.hqx
TabPalette is a shareware utility for placing and modifying tab stops in
QuarkXPress 3.31 or later for Mac OS. It consists of one window showing all the
tab stops applied to a paragraph or group of paragraphs. The position, type of
alignment and fill character of each tab can be modified directly in the
TabPalette window by overstriking the new values or by entering expressions like
2p3+14pt. Several operations can be done to a group of tabs: move, move and
repeat, sort and the ability to save up to 9 tab settings and retrieve them at
any time (good for copying tab settings between different text boxes or even
different documents). Additionally, tabs can be displayed in a relative mode, in
which each of them represents the distance or offset from the previous one.
Requires: Mac OS 7.1 or later, QuarkXPress 3.31 or later, AppleScript.
Shareware: $10.
By Dario Badia, [email protected]
