Download: http://archive.info-mac.org/text/qark/q ... ock-20.hqx
The enclosed demo of a Quark XPress Xtension was distributed by SWIP
Handels AG, the Swiss distributor of QuarkXPress. Please note that SWIP
takes no responsibility for the demo - they just made it available to all
QuarkXPress users here.
I myself have no connection with SWIP, Quark, or the author(s) of the
enclosed Xtension. Following below is the part of the description from the
"Readme"-file. The archive is compressed using CompactPro 1.34.
fcsLock is a QuarkXpress XTension designed specifically for
newspapers and other large periodicals. This XTension will allow a
boss to disable any feature of Xpress so that other users are not
able to modify certain aspects of Xpress documents. fcsLock can
disable any menu item of Xpress, the measurements palette, as well as
any creation tool.
This copy of fcsLock is a demo version, and as such it can't be
configured. It will only disable the first menu item from every menu
of Xpress, as well as the measurements palette, the rotation tool and
the linking tools.
