BBEdit extensions for Textures Rel. 1.1
Download: http://archive.info-mac.org/text/bbe/te ... it-ext.hqx
I have written three BBEdit extensions that facilitate the use of BBEdit
and BBEdit Lite with Textures. Textures is a commercial implementation
of the TeX typesetting language. This is release 1.1 of the extensions.
The three extensions are:
1. Run Textures (version 1.0). Creates a Textures typeset job using the
text in the active BBEdit window.
2. Close Textures Job (version 1.0). Closes an active Textures typeset
job that was begun using the Run Textures extension.
3. Textures (version 1.1.1). This is a BBEdit tool extension that
combines the functions of the Run Textures and Close Textures Job
extensions using a floating window as an interface. This extension can
only be used with BBEdit, not with BBEdit Lite.
The extensions are freeware. More information is available on my BBEdit
extensions web page:
http://members.aol.com/BradH5/bbedit
Brad Hanson
