"Make Reply" BBEdit/EasyView Extension
Download: http://archive.info-mac.org/text/bbe/make-reply-10.hqx
--========================_9168398==_
Version 1.0 of March 95
This extension calls Eudora to make a reply to the current
mail item. Usable from BBEdit and Easy View.
Place the extension into your "BBEdit Extensions" and/or
"EV Extensions" folder. You don't need to restart the
machine, this is not a system extension.
Programmers: Enjoy the source code which shows how to get data
>From Easy View and how to send an event to a script.
Scriptors: A little script enables you to see/modify the real
thing within the extension.
This extension is dedicated to
* Jon Pugh, who told me in a private message
> My point was simply that it is easier AND faster to write code
> which can run AppleScripts rather than to write code which will
> send AppleEvents to another application.
Indeed it is! Thanks.
M. Akif Eyler
Bilkent University
06533 Ankara, Turkey [email protected]
Content-Type: application/mac-binhex40; name="Make_Reply_1.0.sit"
Content-Disposition: attachment; filename="Make_Reply_1.0.sit"
