BBEdit HTML TOC version 1.0
Download: http://archive.info-mac.org/text/bbe/bb ... toc-10.hqx
Most HTML markup extensions concentrate on the appearance of the document,
making it easy to add HTML tags to a text document. BBEdit HTML Tables,
which I released some time ago now is that sort of extension, simplifying
the construction of tables in HTML documents. This extension is different.
BBEdit HTML TOC is an extension for BBEdit which looks at the logical
construction of the document and makes it easier for you to introduce
logical markup. With HTML TOC you can easily create a table of contents for
any piece of text which has been marked up with headings.
It has a number of features to simplify this process including the ability
to set a cutoff point for heading levels that are included, automatic
insertion of the table of contents in either the document or clipboard,
support for relative links and the ability to build the table of contents
in sections rather than all at once.
BBEdit HTML TOC is able to detect the presence of an existing table of
contents and update, replace or add to it and it will reuse names that have
already been applied to parts of your document when appropriate.
BBEdit HTML TOC has been extensively tested on versions 3.5.2 and 4.0.1 of
BBEdit. It requires a version of BBEdit that supports extensions, which
means version 3.0 or later. This software is shareware, with the low fee of
US$5 payable directly or via Kagi. Please read the enclosed read me for
details.
Stephen
Dr. S J Marshall, Macintosh Consultant, Victoria University of Wellington,
PO Box 600, Wellington, New Zealand
Home Page: http://www.vuw.ac.nz/~marshall
