BBAutoComplete-1.4.1.dmg
Download: http://archive.info-mac.org/text/bbe/bb ... te-141.hqx
BBAutoComplete adds word auto-completion to Affrus, BBEdit, Mailsmith,
Script Debugger, Smile, Tex-Edit Plus, and TextWrangler. You type the
start of a word, press a key, and BBAutoComplete types the letters to
complete the word. If BBAutoComplete guessed wrong, you can keep
pressing the key to cycle through other possible completions. Other
auto-completion utilities need to be taught the abbreviations and
expansions that you use; BBAutoComplete avoids this hassle by
automatically looking for expansions in the program's open documents.
This means that it always suggests completions that are relevant to
your current task.
Requirements: Mac OS X 10.2 or later
More Info:
