Download: http://archive.info-mac.org/text/yellow-view-212.hqx
Need you a fast way to build stand-alone multi page documentation? or a
Reference system? or a Help System? Should have, the program you need, a
very low cost? Should be, the applications created, under free distribution?
YellowView is what you want!
You may build a YellowView's stand-alone documentation by dragging text
files onto its icon or onto its window or by means of menus. You may create
68k, PPC or FAT binary YellowView's applications.
YellowView's stand-alone documentations are WASTE based applications having
some special features:
Any individual page has no 32K text size limit. Full WorldScript support.
Double-byte/bidirectional scripts support. Multi-styled text. Drag Manager
support. Translucent Drag-and-Drop. Embedded objects (images, sounds,
QuickDraw3D, QuickTime). Real tabs. Fully justified text.
Command-clicking of URLs (by using Internet Config). Text selection.
Bookmarks. Live scrolling. SmartScroll support. Searching and opening of
text selection (simple hypertext feature). Search features (also across
the whole application). SpeechManager support. Custom icon for any
individual page. Full support od SimpleText text documents.
Last, but not least, YellowView's stand-alone documentations support five
kind of AppleEvents, with related AppleScript commands, for searching
words or pages. This feature allows to configure YellowView's applications
as Help or Reference System.
YellowView Builder is SHAREWARE. All YellowView's stand-alone
documentations can be freely distributed.
YellowView is Appearance Savvy, Internet Config, Icon Service and
Navigation Manager aware. It requires at least System 7 to run
Author: Rocco Moliterno
mailto: [email protected]
http://yellowsoft.tsx.org
YellowView page:
http://www.geocities.com/SiliconValley/ ... wview.html
What's new in 2.1.2 version
SimpleText's 'PICT' and 'snd ' resources support. 'icns' resources support.
Windows position saving. Improved Modal Dialog filters. Better error
checking. Better error infos. Addresses update. Code optimized for better
performances. Improved Internet menu. Navigation Manager aware. Removed
registration form from About Box. Added Registrations folder. Added
Support folder.
