The Indexer 2.0 - an automated indexing program for yearbooks
Download: http://archive.info-mac.org/text/the-indexer-20.hqx
The Indexer is a program which is designed to work with PageMaker to index
yearbooks in a fully-automated manner. In most cases, an index can be
created for a yearbook with no previous preparation. The program takes a
list of names that you give it and looks for those names within your
yearbook. When it ifnds one, it indexes that person to that page. Every
page of your yearbook can be done at once, as fast as 5 seconds per page!
Try to find a staff member who is that fast, I know I never was!! I've done
the entire index for a 272 page yearbook in less than a half an hour
without any previous preparation.
The Indexer includes many features which are specialized for yearbooks.
Nicknames are fully supported and you can use the supplied list, add to it,
or create your own. Class levels can be included in the yearbook as can
titles for professors and staff members. The Indexer can also be easily
integrated with your existing yearbook templates for PageMaker.
Technical Support
Technical support is absolutely free and is directly from the author of the
program. I can be reached via e-mail at [email protected], or you can go to my
web page for 'The Indexer' at
for more
information.
Technical support is available for both registered and unregistered users.
Todd
