TextToMac 1.32
TextToMac 1.32
Download: http://archive.info-mac.org/text/text-to-mac-132.hqx
[TextToMac 1.32]
TextToMac converts the end-of-line code of text files between
Macintosh, MS-DOS/Windows, and UNIX formats.
** Please replace older version of TextToMac with this version. **
There was a bug that the conversion is incorrect when the last byte of
internal I/O buffer of TextToMac is EOL code. In that case the EOL
code is skipped, that is, the two lines are merged into one line. You
may happen to meet this bug with the files larger than 128k and the
probability is 1/(average length of lines).
Changes:
1.31
Add "Convert Folder" option.
1.32
Fix bug mentioned above.
Required System 7 or later. Freeware.
Takahiro Sumiya
