TextSpresso 1.0 68K - text cleaning/filtering utility
Download: http://archive.info-mac.org/text/text-spresso-68k.hqx
TextSpresso is an intuitive, professional level text filtering
application with over 80 filters. TextSpresso can:
* Clean up E-mails, Web pages, and other text from the Internet.
* Prepare text for the Internet to insure that it is readable regardless
of end destination.
* Convert text files between Mac and PC.
* Prepare documents for HTML publishing .
* Prepare documents for print publishing.
* Whatever you need with 7 user editable filter types.
TextSpresso is ideal for both professional and casual use. With features
like Hot Filter (i.e. filter the selected text in any Mac application),
multi-threading, 100 levels of undo, and batch processing, TextSpresso is
the premier Mac OS text cleaning application.
TextSpresso requires the following:
* A Macintosh or 100% compatible clone with a 68020 or higher processor.
TextSpresso is optimized for PowerPC.
* Mac OS 7.x or 8.x, including Mac OS 8.5.
* A minimum of 2.5 MB of hard disk space for the complete install
(including manuals, sample files, etc).
* A minimum of 2 MB of free RAM for the PPC version, and 2.5 MB for the
68K version.
