ValueFax 2.0.15
Inter-computer communication software: Modem dialers, file transfer, telecommunications, etc.
ValueFax 2.0.15
Download: http://archive.info-mac.org/comm/value-fax-2015.hqx
ValueFax is the first shareware fax program for the Macintosh.
This is a commercial quality, full function product with QuickFax,
fax driver, full reception and conversion of the fax in background,
installer, and an online manual. Versions of this product have
been shipping commercially under different names for several years.
The basic product has been thoroughly tested in a variety of Mac
configurations using a variety of Class 1 and Class 2 modems (this
product will not work with modems that support Class 2.0 only or
with Apple's express modems or with Apple's Geoport modems).
Why would you want to use this product?
* you bought an external fax modem for your PC but you would
also like to use it with your Mac.
* you bought an external fax modem for the Mac but the software
that came with it is too "lite" for your work. The bundled
software may not even work in your configuration.
* you are not happy with your current fax software because it is
old and does not have all the features of ValueFax. What's more,
your current software looks like it has been ported from its
PC (ugh!) version.
* Your company owns several Macs and you are looking for a site
license instead of buying individual copies for everyone.
Support is available via email to [email protected]
We want this product to work in your configuration and we will
do our best to make it work.
