Announcing the release of TEKS Master 1.0. This software has been developed to expedite the distribution of the TEKS information to the educational community. The Texas Essential Knowledge and Skills (TEKS) was developed by the Texas Education Agency as a result of legislation contained in Senate Bill 1. TEKS were developed for sixteen content areas. This is the first significant revision of curriculum for public education since the Essential Elements were implemented in 1984.
The most important features of TEKS Master Software are :
€ Works on most Macintosh® computers.
€ TEKS information can be retrieved quickly.
€ Specific text can be found using the find feature.
€ TEKS Master Software is a stand-alone application.
(This means that you can install it on your Mac and
use this software regardless of the word processor
that you are using.)
€ You can export text to be used in other applications.
€ Does not require a lot of memory to run.
€ Can be distributed via intranet networks.
€ Each grade level has a seperate chapter for easy
access.
€ Does not weigh 80 pounds and use three feet of
shelf space like the paper version does. ( Measurements
are approximations based on previous versions of the
TEKS.
€ Copies can be distributed at a fraction of the cost of
printing, distributing and storing paper copies.
For more information, please read the file enclosed, or contact me at [email protected].
You can also visit WestKey Solutions web page at http://pw2.netcom.com/~rbarrus/WestKey.html .
Roger A. Barrus
WestKey Solutions
