Updater for Eudora's Speller
Download: http://archive.info-mac.org/text/spellswell-7-to-21.hqx
The enclosed updater application will update your older Spellswell 7 2.0.x
to version 2.1. It will not update Spellswell 7 versions older than 2.0 or
Spellswell 7s that have been somehow modified. (Please contact us at
[email protected] if the updater has trouble - we'll send you a Spellswell
7 2.1.)
If you received an older Spellswell 7 with Eudora Pro 2.x you must contact
Qualcomm, Inc. at http://www.eudora.com to upgrade your Eudora Pro to 3.0,
or purchase Spellswell Plus from Working Software for $14.95 at
http://www.working.com.
This updater will not work to update Spellswell Plus. (A free Spellswell
Plus 2.1 updater is located on our "How To Upgrade" web page at
http://www.working.com.)
Dave Johnson [email protected]
Working Software, Inc. Web page: http://www.working.com
PO Box 1844, Santa Cruz, CA 95061-1844 (408) 423-5696 FAX (408) 423-5699
